Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Cleaning and Detailing Forum
Rhino Shine Ultra on running boards
This is a discussion on Rhino Shine Ultra on running boards within the Ford Raptor Cleaning and Detailing Forum forums, part of the Ford Raptor Forums - General Information category!
First post ;) My 11 Screw running boards are starting to look a little gray even after a few really ...
Like Tree3Likes
  • 1 Post By crash457
  • 1 Post By Dachuri
  • 1 Post By 3Ktt
Sponsored By: Adam's Polishes
Old 05-21-2017, 07:21 PM   #1 (permalink)
Junior Member
Default Rhino Shine Ultra on running boards
First post ;)
My 11 Screw running boards are starting to look a little gray even after a few really good cleans with Simple Green and a scrubbing brush.
I bought some Rhino Shine Ultra Black to refurbish the running boards.
Have not really seen it mentioned on a search. Is there anyone with any experience using this?
It is applied with a paint brush.
Unbolt running boards and do all parts or mask up the underside of the doors and apply with them on the vehicle?
GVW299 is offline   Reply With Quote
Old 05-23-2017, 01:00 AM   #2 (permalink)
AdamsPolishes's Avatar
Originally Posted by GVW299 View Post
First post ;)
Welcome to FRF!
I have not heard of anyone using that particular product on the faded running boards, but I can offer another suggestion.
First suggestion would be to only use Simple Green or any other similar type of cleaner on the running boards when absolutely needed. Since these types of higher pH cleaners can actually speed the rate of fading, they should only be used when a milder cleaner, in conjunction with scrubbing and rinsing, does not get them clean.
Once you get them cleaned, try our VRT Dressing to help bring back some of the color. You may need a few different applications, as part of your normal washing routine, to get some darker color back into the running board material.
The VRT can make them a little slick, so do not over-apply, since only so much product can actually soak in before it air dries, and any product left sitting on top of the surface can be very slippery, especially when it gets wet. About 20 minutes after applying, you can go back over it with a dry towel to remove any excess, and then let it dry, preferably overnight.
Take some before pics, then compare those to how the boards look after a few weeks of using the VRT.
While these are not Raptor running boards, these pics are an example of what this product can do on faded plastics:
use the code RAPTOR for 10% off your next order
Toll Free: (866) 965-0400 | Email: [email protected]
Check this out:
AdamsPolishes is offline   Reply With Quote
Old 05-25-2017, 11:54 AM   #3 (permalink)
crash457's Avatar
I'm Batman
Originally Posted by AdamsPolishes View Post
Welcome to FRF!
Attachment 88643
Attachment 88644
VRT is no joke. This stuff is amazing. It can revive almost any black trim. Here are some shots of what it did on the flare and door handles on my old Silverado. This plastic trim had 15 years of oxidation and fading and VRT made it look brand new. After I applied it, I wiped of any excess and it dries to the touch with no oily residue. It works great for tires too.
AdamsPolishes likes this.
2017 Ruby Red SCREW 802A-Ordered 8/3, Built 10/14, Released from Factory 12/12, Accepted by Shipping Company 12/27, Delivered 1/19
crash457 is online now   Reply With Quote
Old 05-25-2017, 03:59 PM   #4 (permalink)
EricM's Avatar
Took a pressure washer to mine last weekend after I was done pressure washing my mower deck. Turned out real nice.
2013 Tux Black SuperCrew.
Nobody gives a crap where your post was sent from...
EricM is offline   Reply With Quote
Old 05-25-2017, 11:43 PM   #5 (permalink)
You heard the crashman! Get some VRT!
And save 20% with the Memorial Day Sale!
Check this out:
Old 05-30-2017, 09:25 AM   #6 (permalink)
Junior Member
Because no one has seemed to have done it yet, will take my steps off next weekend and Rhino Shine as a test. This is a more permanent solution then maybe the VRT to maintain.
Old 06-26-2017, 07:19 AM   #7 (permalink)
Dachuri's Avatar
Anybody have any experience getting wax or sealant out of the running boards?
I gave my Gen 2 its first steak (clay, polish and sealant) and dripped some sealant on the running boards (full details in a closed, non-temperature controlled garage in Texas, in June is not a fun job).
I read on another forum that peanuts or vegetable oil were good at removing wax residue from trim so I tried applied vegetable oil with a toothbrush. This actually turned out really nice, left a deep black finish and I ended up dressing both running boards in full with it. I washed my truck again over this past weekend and my pressure washer seems to have taken off all the vegetable oil but the sealant marks are still there. Much more faded than before but still there.
I have a garage full of Adam's products but do not own VRT (currently use 303 and Opti-Bond tire gel for my trim). I have no problem adding VRT to my next Adam's order but I believe VRT will only cover the stains, not remove them, and I'm looking for a product that has been verified to remove wax/sealant from these specific running boards.
2017 Magnetic SCREW 802A, SPD Adapters, S&B CAI, custom graphics by ZillaWraps, Suntek Ultra, all glass tinted, RPG 2.5" perch
Dachuri is offline   Reply With Quote
Old 06-27-2017, 12:31 AM   #8 (permalink)
Bummer with the stains! As you found out, those internet tales of vegetable or peanut oil removing stains are not true, since the oils really just mask the residue.
You are also correct in your assumption that VRT will also mask the problem, since it is not a cleaner, but a conditioner.
To remove the residue, use Tire & Rubber Cleaner at your next wash. Spray the area well, then scrub like the dickens with a small, stiff brush, and rinse really good Simply wiping with a cloth or wash pad will not work, since the residue is down in the texture of the running board.
Depending on the type of sealant (ie how durable it is), and also on the pre-stain condition of the running board (ie whether it was conditioned well, or if it was dried out from sitting since the truck was built), it might take a few scrubbings during subsequent washes to work the stains out.
This is were the VRT can help. After the scrubbing/washing, apply VRT to the running boards and let it soak it. Adding this conditioner will help work the stain out of the running board finish.
Also, we recommend always treating the plastic and rubber trim, and in the case of Raptors, the running boards, with a good coat of VRT right before waxing or sealing, since it soaks in and moisturizes these surfaces, so that if the wax or sealant accidently gets on them, it is easy to wipe off, since it does not soak in at all.
Just a quick word of caution, the VRT will make the running boards a little slippery for the first few days, especially if they get wet, so be careful. It is usually good after a few days of drying.
Good luck, and let me know how it goes.
Check this out:
Old 09-10-2017, 02:59 PM   #9 (permalink)
Junior Member
I would make another new suggestion. I have a 2017 and have used Adams In and Out spray to dress them after cleaning them. They are more slick, but the spray does a great job of coating them evenly. They are now nice and black.
3Ktt is offline   Reply With Quote
Old 09-10-2017, 11:18 PM   #10 (permalink)
I&O FTW!
Thanks for the recommendation!
Check this out:
Running Boards D1rtman Ford Raptor Problems and Questions Forum 1 08-29-2016 05:07 PM
Running Boards Mr Roarke Ford Raptor Exterior Forum [GEN 2] 8 08-25-2016 12:12 AM
Amp running boards :||Raptor||: Ford Raptor Exterior Modifications Forum [GEN 1] 41 02-10-2015 05:24 PM
Running Boards MTF Ford Raptor Cleaning and Detailing Forum 48 05-14-2012 08:23 PM
Running Boards TuckerTravis Ford Raptor Exterior Modifications Forum [GEN 1] 20 04-29-2012 06:25 PM
