Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forum Supporting Vendors > Southern Car Parts
Southern Car Parts
2017 ford raptor magnum force stage 2 pro dry s cold air intake system
This is a discussion on 2017 ford raptor magnum force stage 2 pro dry s cold air intake system within the Southern Car Parts forums, part of the Ford Raptor Forum Supporting Vendors category!
2017 FORD RAPTOR MAGNUM FORCE STAGE 2 PRO DRY S COLD AIR INTAKE SYSTEM - $799.00 The 2017 Ford Raptor ...
Old 06-27-2017, 02:28 PM   #1 (permalink)
Default 2017 ford raptor magnum force stage 2 pro dry s cold air intake system
The 2017 Ford Raptor Magnum FORCE Stage 2 Pro Dry S Cold Air Intake System outflows factory intake by 67% with its 3-1/2in mandrel-bent, brushed aluminum design intake tubes for balanced intake pressures and maximize airflow and velocity. Its aluminum one-piece heat shield utilizes stock mounting locations.
Dual Inlet Large 3-Layer "Oil-Free" Performance Air Filters:
This intake system utilizes oil-free, large 7" tall radial flow performance air filters with 3-Layer progressively finer porosity synthetic media for maximum convenience.
Top Mounted Heat Shield Design:
aFe developed this aluminum heat shield to snap onto the top of the lower half of the factory air box to provide a hassle-free installation utilizing factory mounting locations.
Equal Length Intake Tubes:
Dual mandrel-bent brushed aluminum equal length intake tubes are designed with an H-pipe to balance intake tube pressures and maximizes airflow and velocity.
Hassle-Free Installation:
All clamps, couplings, and hardware are included for hassle-free installation. This is a direct bolt-on kit that requires no cutting or drilling on factory parts.
Note:
This product is not currently CARB exempt and is not available for sale in California or for use on any vehicle registered with the California Department of Motor Vehicle.
APPLICATION: 2017 FORD F-150 RAPTOR
http://www.southerncarparts.com/2017...ke-system.html
Ford Raptor Parts and Accessories
888.631.1433 - www.southerncarparts.com
Exclusive Coupons: FRF7 $7> $99 order | FRF27 $27> $249 order | FRF52 $52> $499 order
Southern Car Parts is offline   Reply With Quote
Old 03-01-2018, 10:37 AM   #2 (permalink)
Thanks for Checking us out. We are always adding new products to our website: https://www.southerncarparts.com/201...d-raptor.html/
2017 ford raptor mach force-xp 3in 409 stainless steel cat-back exhaust system Southern Car Parts Southern Car Parts 0 06-20-2017 12:17 PM
2017 ford raptor mach force-xp 3in 409 stainless steel cat-black exhaust system Southern Car Parts Southern Car Parts 2 06-13-2017 11:05 AM
FS: AFE stage 2 Cold air intake stage accely Garage Sale 4 02-15-2016 12:27 PM
AFE Stage 2 Cold Air Intake System for 6.2L Raptor cpost6 Garage Sale 9 07-27-2015 12:12 PM
aFe Magnum Force Stage-2 Cold Air Intake System with Black Tube and Pro 5R dark1024 Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 0 10-02-2014 06:48 PM
