Corsa 3" Muffler Upgrade Kit for 2017-2018 F-150 Raptor
CJ Pony Parts
Harrisburg, PA
Corsa Stainless Steel 3" Muffler Upgrade Kit for all 2017-2018 F-150 Raptors.
Do you want a new aftermarket muffler for your 2017-2018 Raptor? If so, take a closer look at this Corsa Stainless Steel 3" Muffler Upgrade Kit that's now available from CJ Pony Parts!
Features & Benefits:
- Same Sport Sound Level as Corsa Cat-Back Exhaust Systems
- Allows You to Connect to and Retain Stock Tailpipes
- Made of 304 Stainless Steel
- Patented Reflective Sound Cancellation Technology Creates Drone-Free Exhaust Sound at Cruising Speed
- Custom-Tuned, Aggressive Exhaust Note Styled Specifically for Your Raptor
- 304 Stainless Steel Adapters Connect to Stock Tailpipe Assembly
- Flows 11.15% Better than Stock and 6 Lbs. Lighter than Stock
- Easy Bolt-On Installation: No Welding Required
- 3"-Diameter Tailpipes Include Strategic Clearance and Heat Shields (Not Included, Available Separately)
This Corsa (14398) Stainless Steel 3" Muffler Upgrade Kit offers the same sport sound level as Corsa cat-back exhaust systems, and you can connect to and retain your stock tailpipes. This muffler is made of durable 304 stainless steel and features patented reflective sound cancellation technology that creates a drone-free exhaust note at cruising speed. Plus, this muffler has been custom-tuned for a loud and aggressive note for your Raptor and flows 11.15% better than stock and weighs in at 6 lbs. lighter than stock! You'll also get 304 stainless steel adapters to connect this muffler to your stock tailpipe assembly, and the installation process itself is quite easy. It's a simple bolt-on process that won't require any welding.
With the performance exhaust products from Corsa, you can get some major performance gains plus, with their patented RSC technology, get reduced exhaust drone in your cabin while cruising.
Order a Corsa (14398) Stainless Steel 3" Muffler Upgrade Kit for your 2017 or 2018 F-150 Raptor from CJ Pony Parts today!
93,171
56,440
jumpcutter
