Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Lighting Forum [GEN 2]
Rough Country Fog light kit installed
This is a discussion on Rough Country Fog light kit installed within the Ford Raptor Lighting Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Just installed the Rough Country Triple 2" cube kit in my 18 SCREW. Kit is only $299 which is quite ...
Like Tree12Likes
Old 06-03-2018, 08:01 AM   #1 (permalink)
Default Rough Country Fog light kit installed
Just installed the Rough Country Triple 2" cube kit in my 18 SCREW. Kit is only $299 which is quite the bargain compared to the $1000 kits I've seen from other vendors. The brackets and cubes appeared to be of good quality and relatively easy to fit and adjust.
I installed each pair to a separate upfitter switch so I can control the exact output of light desired. Very pleased so far, I'll get some light output pics later
Rough Country kit
smurfslayer and ChrisJTX like this.
2018 Leadfoot SCREW/802A/Techno/moonroof/tailgate step/bed ext/cast wheels/Forscanned/Hellwig sway/RC lights/Dynamat factory sub/Flowmaster FX
eclou is offline   Reply With Quote
Old 06-03-2018, 08:21 AM   #2 (permalink)
23,000 lumens for 1000$ vs 8,000 lumens for 300$ seems about right. Can you change lenses like the baja designs?
"The only good pace is a suicide pace and today is a wonderful day to die"
reaper1441 is offline   Reply With Quote
Old 06-03-2018, 01:22 PM   #3 (permalink)
Not certain? The cubes I received were the Black Series. The're a 30 deg spot throw pattern. They include solid covers for rock protection.
Old 06-03-2018, 02:13 PM   #4 (permalink)
nikhsub1's Avatar
Nevermind, read it wrong
nikhsub1 is offline   Reply With Quote
Old 06-03-2018, 06:39 PM   #5 (permalink)
I’d love to see this kit vs the more expensive kits at night. Anyone do a comparison like that?
Carnut is offline   Reply With Quote
Old 06-03-2018, 09:28 PM   #6 (permalink)
Originally Posted by Carnut View Post
Iíd love to see this kit vs the more expensive kits at night. Anyone do a comparison like that?
It's been done. It's a 1/3 the light output. You can't swap lenses and they usually end up with water in them. But 1k for lights is a hard pill to swallow for most people. And most people arnt hitting stream crossings at 60mph or need 25k lumens worth of light because they drive 100mph at night on gravel roads.
I like baja designs because I use my truck at work at night off-road. But I'm also ashamed at how much I've spent on lights...
Old 06-04-2018, 11:34 AM   #7 (permalink)
Junior Member
It is a decent kit for the money...so far I have been happy with it as well. Light output is good for what I need it for.
nick71692 is offline   Reply With Quote
Old 07-09-2018, 03:52 PM   #8 (permalink)
Junior Member
Rough Country kit
Eclou,
When you installed the harness to your upfitter switches did you eliminate the relay that came with the harness of the RC lights?
CaptSteve is offline   Reply With Quote
Old 07-09-2018, 04:04 PM   #9 (permalink)
Originally Posted by CaptSteve View Post
Eclou,
Yes no need for the relays. I just cut out and used the positive and negative wires for the light kit
ChrisJTX and CaptSteve like this.
Old 07-09-2018, 04:27 PM   #10 (permalink)
OP: Thatís great !
Iíve got inexpensive lights and B/D lights that I too am not willing to publicly admit how much I spent on them. Even though I bought them all on sale.
SO I SAVED. I thought that meant something to you penny pinchers
I did skimp and make my own mount from angle aluminum, but Iím happy with the results.
smurfslayer is offline   Reply With Quote
Rough Country 54" Radius Light Bar KRoyal Ford Raptor Lighting Modifications Forum [GEN 1] 4 11-03-2017 06:43 PM
Rough country light bar Mkarban Ford Raptor Lighting Forum [GEN 2] 4 04-24-2017 08:47 PM
Rough Country 54 Inch Curved Light Bar raulsterXDozer Ford Raptor Lighting Modifications Forum [GEN 1] 16 01-12-2016 10:44 PM
WTB: Rough Country winch plate oplersx Want to Buy 0 04-23-2015 01:55 AM
FS- Rough Country drop shackles NickPic83 Garage Sale 4 03-20-2015 07:38 PM
