Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Lighting Forum [GEN 2]
Does rigid make a “[email protected] bracket?
This is a discussion on Does rigid make a “[email protected] bracket? within the Ford Raptor Lighting Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
RigidAZ, RigidIndustries
Like Tree7Likes
Old 04-08-2018, 12:00 PM   #1 (permalink)
Default Does rigid make a “[email protected] bracket?
Installing my rigid fogs with the diode dynamics mounting bracket.
Does anyone know if Rigid makes a “shorter” mounting bracket? When mounted the bumper is covering a small section of the bottom of the fog.
chujk1985 is offline   Reply With Quote
Old 04-16-2018, 11:52 AM   #2 (permalink)
Uncas's Avatar
Same Issue with the D-SS, I talked to Rigid Support and they are passing it on to the engineers since I was the 10th call they have had about this. Email them and we'll see if we can get them moving faster.
https://www.rigidindustries.com/contact-us
2012 Black Screw 165k from Cape Hatteras to Yellowstone, Key West to the Adirondacks.
2018 Magnetic Screw Bought from Dealer Inventory 2/3
Uncas is offline   Reply With Quote
Old 04-16-2018, 11:54 AM   #3 (permalink)
Thanks for the info! I am seeing others mounted pretty flush with the bumper cut-out. It seems like there are some shorter brackets out there?
Old 04-16-2018, 12:09 PM   #4 (permalink)
Uncas's Avatar
You find them, post it. I would love to pull mine up about 1/2 inch.
Old 04-16-2018, 12:17 PM   #5 (permalink)
Uncas's Avatar
The more I look at the website, I think they changed up the bracket.
I would love this height............................................ ............... Which looks nothing like this.
Old 04-16-2018, 12:39 PM   #6 (permalink)
I was thinking the same thing, but I couldnt be certain since the "shape" and "features" of the bracket look the same. I didnt know if it was just the photo that made it look different. I could not find any dimensions of the two.
Also, I was wondering if the bracket could be fitted going the opposite way. Instead of pointing the bracket towards the front of the light, point it towards the rear. I havent had the time to experiment, but it is probably unlikely that it would work.
---------- Post added at 11:39 AM ---------- Previous post was at 11:38 AM ----------
Did you flip the front housing to get the "Rigid" lettering right-side up?
Old 04-16-2018, 12:49 PM   #7 (permalink)
Uncas's Avatar
1. I tried that, but it would not work.
2. Yes, don't tell Rigid.
Old 04-16-2018, 02:07 PM   #8 (permalink)
downforce137's Avatar
two things..
1.i think your rigid brackets are on backwards..
2. can the diode brackets be on the wrong sides of the truck? I thought the bend was supposed to go up in the rear of the bracket/truck if that makes sense.
CROOKS likes this.
downforce137 is offline   Reply With Quote
Old 04-17-2018, 03:00 PM   #9 (permalink)
Spin the bracket around and mount the light as high as possible.
Rigid D2 fog, spot, flood on an L channel of aluminium.
Uncas likes this.
CROOKS is offline   Reply With Quote
Old 04-17-2018, 05:42 PM   #10 (permalink)
oh, so it does work. Uncas up above was saying it would not work for him. I will give it a try.
Rigid fog light bracket question Digger Ford Raptor Lighting Forum [GEN 2] 70 04-15-2018 10:39 PM
GEN 1 Rigid D2's in a Baja Designs Bracket DHW Ford Raptor Lighting Modifications Forum [GEN 1] 14 11-20-2017 07:06 PM
KC 20 Inch Bar With Rigid Bracket? Aventador22 Ford Raptor Lighting Modifications Forum [GEN 1] 3 06-13-2014 12:57 AM
Help with Rigid Dually / Bracket Mount RaptorScrew Ford Raptor Lighting Modifications Forum [GEN 1] 24 12-09-2013 01:58 AM
Rigid fog bracket fasteners- ADVICE aR4CE Ford Raptor Lighting Modifications Forum [GEN 1] 11 05-24-2013 09:34 AM
