Wheel backspacing help
Msb.19d
Broadway, NC
ok so the wheels I want are method con6 , the 17x8.5 0/4.75 bs will have my tire sticking out around 1.5 inch’s I was told by someone on here. I’m fine with that, I want them to stick out alittle further.
My problem is I’m wanting to get the 18in wheels, the exact size and info is 18x9 18/5.75 bs, I have no idea what all this means, can someone please tell me how these will fit? How far will they stick out vs stock. The 17s are 8.5 Wide and 0/4.75, the 18s are 9in Wide and 18/5.75 bs. Can someone please make heads or tails of these numbers for me. I greatly appreciate it if you will.
Micha
Illinois
Rough math says they will stick out 28mm more than stock with a +18 offset.
I think.
M
Msb.19d
Broadway, NC
Yea it’s more than I can figure, the 18s are half inch wider than stock and have a 18 in front of backspace number which is 5.75..., the 17s are like 1.5 inch further out, I like that, but I gotta be for sure about the 18s if I’m gonna but them, don’t want them sticking out any further than the 17s would.
Micha
Illinois
Wait, I think its 22mm further out than stock. Sorry. Want to see how far a 17x8.5 inch wheel with 0 offset sits? Hold on.
Jeff-Ohio
Cincinnati
I added 1.5" wheel spacers with the stock rims and had some rubbing up front on the inside at full wheel lock. Some very minor trimming fixed the issue, but thought this information might be helpful.
Pacific Wheel
Reno, NV
Does anyone know if a 18 by 9 with a 0 offset with 5.00 of backspace will fit on a raptor and not rub anything
Tire dependent you might get a slight rub but it will be minor (fender liner). Leveling the front should help with clearance as well.
