Access to Front Frame Rails
rocket
I'm slowly narrowing down options for winch mounts on my truck
For those of you who've removed your bumpers, HOW DOES THE GRILL COVER IN FRONT OF THE LOUVERED INTERCOOLER COME OFF? i.e. how much of the bumper and skid plate do i have to remove to get it off. See pic below (red square). I'd like to look at the access to front frame rails
have a cradle mounted winch which can be used in rear receiver (need to make longer power cables)
i think with the cover off, you could access the rails and weld hitch receivers to the top of them, then figure out how to replace the cover
normal driving - intercooler grille cover ON
rear recovery- attach winch to rear receiver
front recovery- attach "Y" trailer hitch bar to front receivers, then mount winch.
thanks guys!
Bark beetle
Northern NM
We are on the exact same page. My only concern is blocking air flow to the IC. Until my truck gets here I won't know if that is or isn't going to be an issue. I'll be watching how your's goes.
Sent from my iPad using Tapatalk Pro
Huck
Chicago Sw Burbs
from watching that video, it looks like there is extra plastic all around the frame rails to create a box into the IC.
Kinda ruins my plans too.
