Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
Vibration In Gas Pedal
This is a discussion on Vibration In Gas Pedal within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Originally Posted by _M_ So far he's about the only one that has had any issues whatsoever. I agree with ...
Like Tree18Likes
Old 01-07-2017, 12:46 AM   #11 (permalink)
waddellw's Avatar
I agree with you it could be just bad tires. Or it could be he got a rare bad one and Ford needs to make it right. Main thing is document everything
Sorry! Thought I had read a few different ones on the forum I guess not.
Still, best of luck!
waddellw is offline   Reply With Quote
Old 01-07-2017, 09:27 AM   #12 (permalink)
Originally Posted by Vince View Post
Is only the gas pedal vibrating?
Pretty much. I can feel some vibration in the seat as well, but only when hitting the gas. I don't feel anything while coasting at any speed. Thoughts?
Jeff-Ohio is offline   Reply With Quote
Old 01-07-2017, 10:00 AM   #13 (permalink)
possibly driveshaft or rear end.
Most likely a driveline issue if it's only doing it when you're on the gas
Godbeymike1 likes this.
03'Darin is offline   Reply With Quote
Old 01-07-2017, 10:13 AM   #14 (permalink)
ZaneMasterX's Avatar
No this is his second post with issues with his truck. Personally I think its driveline/tranny/transfer case issue. Good chance he got a hoopty and the best thing to do is get on Fords ass about making it right. 100% of trucks built will not be 100%, its just a fact of mass production and he probably drew the short straw and got a truck with something messed up.
waddellw likes this.
ZaneMasterX is offline   Reply With Quote
Old 01-07-2017, 10:49 AM   #15 (permalink)
Vince's Avatar
My guess is bad drive shaft run out. The tech should use a dial out indicator to measure the drive shaft at the front, middle and rear. If it exceeds 0.035in they need to replace the drive shaft. If that does not fix the problem I have a few other ideas but I'd start there.
I hope this isn't a problem that'll plague these trucks similar to the drive shaft clunk of the GEN1s
Vince is offline   Reply With Quote
Old 01-07-2017, 02:17 PM   #16 (permalink)
To all ..... I really appreciate everybody's help and support. I just got done driving a Limited edition F150 with a 10 speed tranny and it definitely does not exhibit the same issues that I am experiencing with my Raptor. I now have an appointment for this Friday to get things looked at. I will keep everybody posted on what I find out.
Oris19 likes this.
Old 01-07-2017, 02:20 PM   #17 (permalink)
Ok good luck. May take some patience but I'm sure they'll figure it out.
Keep us posted.
Oris19 and Godbeymike1 like this.
Old 03-02-2017, 09:46 PM   #18 (permalink)
Any updates? Thanks
Shockm is offline   Reply With Quote
Old 03-02-2017, 10:03 PM   #19 (permalink)
Are you sure that the excitement of driving a Raptor isn't just making your leg quiver?
AKSteve is offline   Reply With Quote
Old 03-02-2017, 10:50 PM   #20 (permalink)
Check the F150 forum, vibration in gas pedal is a common problem, with lengthy discussion
daaaaaan is offline   Reply With Quote
Tags
drive, gas, issue, vibration
Steering Wheel and brake pedal vibration after brake job BigGriff023 Ford SVT Raptor General Discussions [GEN 1] 7 07-19-2016 08:30 PM
Dead Pedal and Powdercoated SRP Pedal Kit Sitdown Garage Sale 7 07-07-2016 08:20 PM
AFE CAI vibration RedTailHawk 5 Star Tuning 3 05-25-2012 04:11 PM
Gas pedal vibration Warhog99 Ford Raptor Problems and Questions Forum 4 04-26-2012 12:26 PM
