Poor brake performance, slotted/drilled rotors?
jes.jr
Massachusetts
Anyone else feel the brakes are almost scary under powered? My truck did sit for almost 5 months before I drove it. No vibrations or pulling, just seems mushy and like I have to really stomp on it to stop from high speed. Looking if anyone has had the dealer fix this or should I upgrade to slotted/drilled rotors?
Bullishone
I am. I find the brakes to be weak on both the gen1 and gen2 when any amount of load is on the truck.
jes.jr
jes.jr
Massachusetts
My gen1 was no sports car in braking but the gen2 is way faster so maybe that is why I see a real problem with the brakes now.
darkneo
Los Angeles
Different rotors won't fix pedal feel. You could check the fluid and bleed them. Or maybe upgrade to stainless steel lines.(Not sure if stock lines are already ss lines)
Jake17
★ REBEL LIFE ★
BREMBO 8 piston fronts > only way to go
floating rotor/aluminum hat
Ballistic
Oregon
Isn't the Gen2 basically the same brake setup as a Gen 1? And why the brakes feels worse is due to the brake boost for the Collision avoidance?
Chris@FreedomMotorsports
FRF Gofur
Woodlawn, Virginia
Anyone that wants them, I have sold a good number of kits for the Gen 2 already, (between 30-40 kits so far this year) and have heard good things about the perceived better braking. Although, stainless lines would help as well, they are still in development.
I have the Gen 2 brake package from R1Concepts listed on my website at the link below and if you use promo code MOTHERSDAY20 during checkout, receive 20% off and free shipping to the lower 48. International shipping available.
https://www.freedommotorsportsraptorstore.com/index.php?main_page=index&cPath=1126_1128_1370
I also offer a BBK from R1Concepts with 6 piston calipers in the front, 4 piston in the rear, two piece floating rotors, stainless lines, performance pads and the ability to color match the center hats with the calipers in a wide variety of painted and anodized colors for less than $4500 out the door for a full front and rear kit.
ericwudi0830
At first I thought my brakes felt weak. After a couple of months the feeling disappeared though
Bullishone
That's a sweet deal. What size rims do you need for that?
---------- Post added at 09:10 PM ---------- Previous post was at 09:04 PM ----------
Are there any specs for these brakes?
