hkguns
- Joined
- Jul 30, 2016
- Posts
- 1,173
- Reaction score
- 892
Tizzle, does your truck have the front Torsen?
I believe so... Standard on 802A, correct?
In the off road menuGreat info! One question: how do I pull up the power distribution screen?
I did some more testing today and I am going to focus on braking performance on loose dirt/gravel in this post, no shifting, throttle response, etc. For me this is the most important function of a offroad worthy vehicle and it has been the source for the first mods on all my trucks equipped with ABS. Poor stopping ability on dirt will lead to disaster. Washouts, rocks, animals, other vehicles coming around a blind corner, I have experienced them all and stopping or slowing down is critical. My Tundra was the single worst vehicle I have ever owned with ABS when it comes to stopping on dirt, it was flat dangerous. I put the ABS on a switch and I would turn it off immediately when going on dirt. Fortunately Ford has given us lots of options with the Raptor.
Weather and Rock crawl modes not tested for these conditions as I would never use either in the terrain where this matters.
Normal mode - ABS kicks on with moderate brake pedal pressure and is very active causing poor stopping ability (not even close to my Tundra though).
Sport mode, 2wd, 4a, 4h, locker on, locker off, trac on - ABS kicks on with moderate pedal pressure but is slightly less active, still fairly poor stopping ability.
Sport mode, 2wd, 4a, 4h, locker on, locker off, trac off (press or press and hold for 30+ sec) - didn't matter which one I selected - ABS kicks on with moderately heavy pedal pressure, decent stopping but could still be better.
Sand/mud mode, trac auto off with mode selection, other stuff didn't matter but I did not try to see if I could go back to 2wd or 4a in this mode (need to do this) - ABS not easily detected even with very heavy pedal pressure, allowed dirt to pile up in front of the tires. As good as dirt stopping is going to get, up to you to optimize pedal pressure for the best stopping performance given the type of dirt/gravel/sand that you are on.
Baja mode, trac auto off with mode selection - ABS performance seemed identical to sand/mud mode which is good.
One strange thing I want to note is during one of my test runs on a slightly rocky road section I experienced a violent response from the electric steering assist and it is a good thing I keep my thumbs out of the spokes! I did have it on sport mode but that was not a good response. My RZR has electric assist and I have never felt that before. Not really impressed with the feel or response of this steering. I definitely prefer good old hydraulic power steering. I can give up V8 but wish I still had hydro!
Sent from my iPad using Tapatalk Pro
