Baja Mode
ThatTorqueTho
Noob question, if Baja mode eliminates turbo lag or is "anti-lag" as Ford calls it, would we be able to drive in that mode on a daily driving basis without harming the truck in someway (Example: overheating). I mean turbo lag sucks, so i see no point in driving im anyother mode(excluding 4x4s)
ovrlnd
You can select Baja and then 2WD and you should be fine. Don't know if 4 Auto would kick you out of it.
gneissday
I mentioned in another thread that you can't use 4 Auto in Baja mode (supplemental manual). But 2wd will work!
HORN HIGH ACES
Colorado
Good call on Baja Mode in 2wd. I found it a bit odd that 4hi is the default. Maybe this is old school thinking, but I would think running 70-80mph in 4hi for an extended period of time wouldn't be ideal for the 4wd system.
BurnOut
I don't know how the "anti-lag" function is implemented on the Raptor, but in the application that I am familiar with (rally cars), it is VERY hard on turbo impellars, as it functions by essentially injecting some fuel during the exhaust cycle, then igniting it with the spark plug. This functions to create combustion in the exhaust port/manifold, and keep the turbo spinning.
If I had to guess, Ford's approach is different... perhaps opening a blow-off or recirculation valve such that the compressor side of the turbo doesn't have the resistance (of trying to force air past a closed throttle plate) slowing it down.
That's a complete WAG, though...
fijidaniel
Dallas
YOu know...right after placing my order I was up in Wyoming for work and actually got a 2016 screw Lariat 4x4 with 3.5L Ecoboost as a rental for a couple of days. I was impressed with that model of engine and didn't notice any lag
FreightTerrain
land of oz
people with post counts under 100. that wont last long. woops, i just made another useless post. add it to my growing list
