TargetBow
- Joined
- Nov 25, 2013
- Posts
- 54
- Reaction score
- 18
I am hoping that everyone with this size Duratrac tire will post what PSI they are running and note if it is on a supercab or a supercrew Raptor because I would think the truck weight differs from Scab to Screw and please post if the wheels are stock size.
I am just curious to see if the PSI everyone is running with these tires on stock size wheels varies by a lot or not.
I am running 43 PSI front and rear at the moment on stock wheels on a supercab Raptor.
When looking to see if all the tread is in contact with the ground when on a flat surface when tires are cold, it looks like not all the tread is contacting the surface so I would assume they are over inflated but not sure.
This is why I would like to see what others with the same tire and wheel combo are running because I was thinking of reducing my tire pressure to about 42 PSI up front and 40 PSI in the rear but want to see what others are running and if all tread is in contact with the surface or not with your setup.
I've looked around alot to find this info but everything varies alot with everyone's tire and wheel setup that I was hoping to narrow down the info to this one tire and wheel combo to see what everyone is running for PSI.
Thanks: Ed
Thanks: Ed
