Brake upgrades
Pt2285
sunset beach CA
any one upgrade their brakes to vented rotors and better pads like the one from stage 3??? If so, thoughts?
Madcowranch
Genetically Modified
OK
EBC slotted rotors, pads from autoanything. SS lines from SDHQ.
Yukon Joe
Russellville, AR
If you off-road your truck in mud, I'd recommend slotted rotors. Not the drilled ones. The holes hold the mud and can cause your brakes to squeal.
I have the R1 Concepts package from @Rookie. Premium cross drilled and slotted rotors with ceramic pads. SDHQ braided lines. It stops!
Thank You for your donations to Avery. We hit our goal!
Yukon Joe
Snoball 3
Delta Lead
www.runraptorrun.com
t_j
Chicago, IL
I'd go ebc they have a very good reputation I've used there rotors and pads on cars and bikes with awesome results and @IRONMAN can get you good prices on them.
IRONMAN
Well-Known Member
MICHIGAN
Thanks Tom, yes I deal in EBC.
I've had them for the past 2 years on my truck fronts only and they work great.
I just bought the rear upgrades and will hopefully put these on when it get a bit warmer.
CoronaRaptor
CANADA
Here's the EBC rotors and green pads on the front, had the rears done as well. I previously had s/s lines installed. Still breaking in the pads, they are quiet even though it says in the instructions that you will get "wind" noise from the rotors, but my SW exhaust covers up any such nonsense.
Pt2285
Pt2285
sunset beach CA
what are we talking for all 4 corners with pads?
