The Split Personality tuner can be used for a couple of different tunes and are not limited to Nitrous. We can change Fuel and Spark (no trans stuff) for a secondary tune.
We can do a Nitrous tune with 5 selectable stages to correct Fuel and Spark for these different stages. We DO NOT CHANGE JET SIZES with the kit. All 2011 and newer Ford vehicles try to achieve a AF ratio of 12.7ish which is not optimal for Nitrous. We can change this with the flip of a switch. If a customer sprays nitrous today and doesn't have a custom tune then the ECM will automatically lean out to improper AF ratio and potentially burn the engine up.
If they do have a proper tune then it will either
a. Run richer when not running nitrous
b. have to completely reflash the vehicle to get on the right tune.
With our Split personality tuner its simply a flick of the switch to get on and off the Nitrous tune.
So if the customer DOES NOT HAVE NITROUS and wants a race gas tune or a less aggressive tune we can also do that so it switches on the fly.
