Gen 3 Whipple Upgrade Testing!!! Results inside
JimIII@JDM
New Jersey
Some of you know we recently installed a Whipple Gen 3 Supercharger on MetroNYC's 2011 Raptor truck. This truck was already running the Whipple Supercharger kit and had our custom dyno tune. The truck had been running the Whipple 2.9L Gen 2 Supercharger with our tune for nearly 4 years. The truck has just over 40K on the odometer, running ARH long tube headers and GREEN cats, Ford Racing twin 65mm throttle body, and 47lb injectors.
It took a little over a day to complete the blower swap, we also installed a fresh set of NGK 6510 plugs gapped at .030" during the install. We strapped it down on the dyno immediately after and made the first pull. We only took it to 4,000 RPM but at that point we saw a 30 HP gain and nearly 30 lb/ft of torque! The next pull we attempted 5,000 RPM but at 4,800 the truck ran out of fuel and it limited throttle angle. We made another attempt and it did it again. After looking at the logs we could see the injectors were maxed out, the truck was making over 500 RWHP at 4800 RPM and running lean.
Previously the truck made 548 RWHP with a 3.25 Pulley (11-12 psi) and was pretty much at the limit of the injectors then. With the new blower, same 3.25 pulley, same boost 11-12 psi the power is coming in sooner now and causing the injectors to peak earlier. So we decided on a larger set of injectors, we ordered Deatschwerks 78 lb/hr injectors and swapped them out last week. We got the truck on the dyno a few days later and remapped the fuel injector tables for the bigger injectors.
Keeping the fuel curve the same and the timing same as well locked at only 12 degrees we made 576 RWHP!! Basically 30 RWHP gain over the old unit. The power didn't just pick up peak, it was from the hit of the throttle all the way through red line 30 HP more the entire run! This is power you will feel seat of the pants. Whipple claims 30+ HP gains and they aren't lying! It's nice to see a company back up their claims.
So now we are offering custom tuning for 78 lb/hr injectors for customers running the Gen 3 blower or who are looking to maximize the potential of their Gen 2 by going to a smaller pulley. If you are interested or would like to upgrade the injectors and tune give us a call at 732-780-0770!
JimIII@JDM
ROCKETW19
damn I wish he had 60s in there I would of liked to see that.
were the 78s needed or you just being safe? or maybe even more upgrades later?
Im pretty sure I seen whipple offer 78s also to bad this info wasn't out 2 months ago lol.
how many lbs of boost is it pushing now?
thanks
JimIII@JDM
JimIII@JDM
New Jersey
Did you guys raise the rev limiter?
Yes from 5800 to 6,000....it kept pulling so we wanted to see what she could do!
---------- Post added at 04:09 PM ---------- Previous post was at 04:09 PM ----------
thanks
11-12 psi before and after
MTF
Celebration, Florida
That's 50+ lbs. more torque than I'm running, that is sweet. That is something you will feel.
And 12 degree spark advance is not even pushing it. Also very nice!!!
Can't wait to do mine in the early spring.
Nice job JDM!
Nice Truck MetroNYC!!!
ROCKETW19
that's awesome all that extra power and the boost is still in the proven safe limits.
best thing is the power starts instantly. exactly where I want it most, looks like some 78lb injectors will be in my future along with this tune.
thank you MTF for pushing me towards the Whipple I would of been pissed seeing this right now If I had bought the Roush.
