Cannot find where to install alternator support bracket on E-force supercharger.
jokerz
Need to order one hit me up
I can place you an order
JimIII@JDM
New Jersey
From their instructions
101. Position the alternator support straps so that they
align with the bolt provisions on the alternator and the oil
filter bracket. Snug the supplied strap bolts, then hold the
alternator firmly against the bracket while torquing the
bracket bolts to 18 ft-lbs, then torque the strap bolts to 8
ft-lbs. Make sure the belt stays between the strap and the
upper bolt boss.
There is a picture if you go to step 101 in the link...
http://www.edelbrock.com/automotive/misc/tech-center/install/1000/1583.pdf
F
i actually need the bracket.
---------- Post added at 08:49 PM ---------- Previous post was at 08:49 PM ----------
I actually need the bracket so yes:)
---------- Post added at 08:51 PM ---------- Previous post was at 08:49 PM ----------
upper bolt boss.
But I'm confused as to where it attaches to the block is all. That statement sort of makes sense, but still confused.
