Winch deals just for you!
aka grumpy car stereo guy
minimum 12k load cpacity, synthetic, and a hookup for a trailer hitch receiver. since i am in colorado there is less high speed stuff and more technical crap. need to be able to winch front and rear
R
RSiWORKS
S.C.S. Michigan
For all the receiver winch mounts you'll most likely need these.
Part Number: S/B35210
Winch Wire Harness
24 foot long copper cable with cover
3 foot winch mount connectors and covers
Quick disconnect
$160.00 shipped
---------- Post added at 02:25 PM ---------- Previous post was at 02:20 PM ----------
I would do this one.
X2O 12K GEN2 Comp Series Wireless Winch
Cost $650.00 shipped
images.ashx
Part Number: S/B98512
Waterproofing: IP68 Rating
Rated Line Pull: 12,000Lbs (5,454kgs) Single Line
Motor: 6.6hp Series Wound
Control: Remote Switch, 12’ (3.7m) lead
Gear Train: 3-Stage Planetary
Gear Ratio: 265:1
Clutch: Sliding Ring Gear
Brake: Automatic Out-Of-Drum
Drum Size: Diameter 2.5”
Cable: 98.5’ 3/8” Diameter
Cable Type: Synthetic Rope
Fairlead: Hawse
Remote Control: Included
Recommended Battery: 650CCA Minimum for Winching
Battery Leads: 25mm2, 72”(1.83m)1
Finish: Textured Black
Weight: 67.0Lbs (30.4Kgs)
Mounting Bolt Pattern: 10.0” x 4.50”
Overall Dimensions: (L x W x H) 22.3” x 5.4” x 9.4”
Unless you want WARN
IRONMAN
Well-Known Member
MICHIGAN
ZEON 10-S Recovery Winch with Spydura Synthetic Rope
images.ashx
Part Number: WAR89611
Rated Line Pull: = 10000 lbs.
Motor: = 12V
Gear Ratio: = 216:1
Size: = 24.25 in. x 7.15 in. x 10.52 in.
Type of Winch: = Electric
Remote Control: = Remote switch, 12 ft. lead
Weight: = 75 lbs.
Synthetic Rope: = 100 ft. of 3/8 Spydura rope
Fairlead: = Hawse
The next generation of winches is here: WARN ZEON. With a modern rugged design, upgraded internal components, and increased performance and durability, ZEON is a new name from the most trusted name in winches. With a bold look and power to match, the ZEON is like nothing you’ve ever seen before. Unique exterior styling and symmetrical design give this winch a look that is advanced, capable, and strong. New-design planetary gear train and series-wound motor deliver fast, quiet, and reliable pulling power. Satin-black powder-coated finish with stainless steel fasteners and clutch lever looks great and inhibits corrosion. Convertible control pack can be attached to the winch or remotely mounted, allowing for various winch mounting options and looks (Relocation kit required and sold separately). Large diameter, aluminum winch drum reduces rope wear, is light weight, and has an integrated rope anchor for easy rope installation. IP68 rated for improved winch sealing to keep the elements out. Backed by the WARN Limited Lifetime Warranty.
Retail Price: $1,149.00 /plus shipping
Contact me for your FRF Discount.
Check them out.
