wireless will not start engine
cees
the netherlands
Help ,
I have a 2011 raptor 6,2l
and I can not start the car wireless anymore with the key! the respond with the horn 2 times , the rest of the key is working wireless
how do I change that ?
I have checked the compter screen in the dashboard but still not going
Iam from europe so if you can help me withe a simpel mail that will be fine !
gretings from holland amsterdam
Blind1
Central Alabama
Under the hood on the driver side, you will note a button near degas bottle check to see if it goes up & down & lines up with the notch plate on the hood and depresses once the hood is shut. Hopefully that will resolve your issue. Good Luck!
Blind1
Central Alabama
I'm at work so I can't post PICs, but it is located on the driver side right behind the Air Cleaner box & before the overflow coolant container. It sticks slightly inward. It is covered with a black rubber boot. Just ensure it's not covered with crude and not stuck or lose. Good Luck
