I figure I should be able to take this
https://www.pciraceradios.com/ProductDetail.jsp?LISTID=-2715141707279728383
Then have a shop make a larger plate that has a whole cut out for the PCI mount and also will have the switches. Have the plate mounted and then mount the PCI unit to that plate
@johndjmix and @Dan06, Thank you guys so much. I have this radio and have been planning to mount it exactly as you have it but wanted to get the fascia/remote head element professionally done. Just got back from the Audio shop where the guy said basically the radio wouldn't fit (too deep) and we need to do a custom replacement panel where the sunglass holder etc is ...yada yada. I just got online to start looking for a unit with a shallower head and found this thread
So glad to see you have this mounted where I want it. After dozens of hours looking at install threads over the last 6 months I don't know how I missed this one!!!
Do either of you have shots of the cut headliner before you put the fascia on or shots of the cuts you made to the back of the head?
Thanks again,
K
