Build Your Own CO2 Tank System – High Quality & Lowest Cost Ford Raptor SVT
MagicMtnDan
Magic Mountain
CO2 Air Systems for Offroading, 4x4, Desert, Sand, Construction, RV, and Commercial Use
On board CO2 tank systems offer incredible convenience to users who can air up tires faster than most any other way even when out in the middle of nowhere. No more hoping a gas station has air or a working compressor and no more buying/carrying air compressors that are costly and take quite a while to air up tires. Plus you can use these at home and you can use them to power air tools anywhere you take the tank.
A 35x12.5 tire can be aired up from 5 lbs. to 30 lbs. in under 2 minutes per tire and you can inflate your tire approximately forty (40) times using a 10 pound tank! By the way, it’s easy and convenient to refill your tank. CO2 tanks and refills are very common – they’re used in the beverage industry, off roading and paintball as well. Beverage companies and industrial gas companies will refill these tanks. The cost to refill typically is in the $8-$12 range (YMMV). Google “CO2 tank refilling” for more info.
As an avid off roader I’ve wanted to be able to air down and back up anytime, anywhere and do it quickly but I’ve always been put off by the high price. My goal has been to come up with a solution that is equal to or better than the CO2 tank system suppliers at the lowest possible cost. Here’s what I’ve come up with.
The Good News
You can pick and choose and put together the best, most cost effective system for your needs. If you want a 10# (pound) tank, which is the most common, you can get it. And if, for some reason, you want a 15# or 20# tank, you can buy them too. It’s your choice.
Start with the tank, then choose your regulator with hardware,
Power Tank and Outback Air are the two primary companies involved in selling on board air systems. Tanks are available in different capacities (weights) and the most popular tank size is 10 pounds (which holds 10 pounds of C02). Here are some of the packages these CO2 system companies offer – these are the package prices to beat:
Powertank
PT10-5200 Basic System with 10lb. tank (“bottle”) is $389.95
POWERTANK - CO2 Air Systems
And if you want a boot and a mounting bracket the package (PT10-5240) is $439.95
Outback Air
Outback Air XD CO2 System Combo (includes a bracket) is $265.00
Outback Equipped | Outback Air CO2 Systems | "Is Your Rig Outback Equipped?"
Both companies offer 15lb. tanks which are even more costly.
Powertank offers a gauge – shouldn’t the regulator have a gauge? The Powertank regulators typically come with a gauge on the regulator but the truth is no gauges are necessary since tank pressure is constant at ~800 psi when there is liquid CO2 left in the tank (the regulator will read full up until it’s empty). How do you know when to refill? You can measure what's left by weighing the tank. An empty tank with a regulator attached weighs ~15 lbs. and 13 lbs. without the regulator. So a 10lb. air tank and regulator with a fresh charge of liquid CO2 weighs ~25 lbs.
What I’ve come up with is an a la carte solution, a menu that allows us to pick and choose and buy what we want – here are the details:
Tanks
10# tank shown (above)
These are brand new aluminum tanks with a CGA-320 valve (this is a standard tank and valve – the same as those used by the above industry suppliers). These are brand new aluminum CO2 tanks not reconditioned steel tanks. Every CO2 cylinder is produced from high strength aluminum alloy 6061-T6. These tanks are popular because they are not as heavy as steel tanks and they do not rust.
A carrying handle is included on the 10, 15 and 20 lb. cylinders. The service pressure is up to 1800 PSI/124 BAR with a test pressure of 3000 PSI/207 BAR. These cylinders are stamped with required U.S. Department of Transportation and Transport Canada Markings. The 320 Valves are CGA approved, and have a male thread for Co2 Regulators. Note that this supplier is in California so CA residents will be charged tax.
Tanks from BeverageFactory.com call 1-800-710-9939 ask for Jesse Glancy
Be sure to tell him MagicMtnDan sent you and he’ll work to ensure you get the lowest possible cost.
10# tank is 7" diameter x 20.5" high 1800 psi – cost is $86.40
http://www.beveragefactory.com/draftbeer/tanks/co2/C10.shtml
15# tank is 7" diameter x 27" high 1800 psi – cost is $91.15
http://www.beveragefactory.com/draftbeer/tanks/co2/C15.shtml
20# tank is 8" diameter x 27.5" high 1800 psi – cost is $109.20
http://www.beveragefactory.com/draftbeer/tanks/co2/C20.shtml
5# tank (ideal for use in your SxS Rhino, RZR, etc.) $56.00
http://www.beveragefactory.com/draftbeer/tanks/co2/C5.shtml
15# tank shown above
Regulators
After a lot of Googling, the best regulator solution I have found is from Outback Air. Their regulators are set at 150 psi and besides being an excellent value, they don't have the unnecessary gauges which will read the same up until the tank is empty. Static regulator complete with fitting and automatic quick connect coupler included. Outback Air regulator $55.00 Outback Equipped | Outback Air CO2 Systems | "Is Your Rig Outback Equipped?"
You can order online and the contact there is Tony. You can call him at 1-800-503-0244 and you can email him at [email protected] Tell him MagicMtnDan sent you.
Hoses
There are many (many) hose options. I’ve done a lot of searching and contacted some people and here’s what I came up with:
A1 Coupling (www.A1Coupling.com) is in Oregon and they claim to provide or have provided hoses and hardware for both Powertank and Outback. I have been working with Dee Evans.
25’ Recoil Air Hose (PURC-14-25R-S-BR-QC) with quick coupler steel, 6-ball and plug steel industrial or automotive style. This is a spiral (coiled) reinforced hose with steel coupler plugs and brass tire chuck. 250 WPSI 4 TO 1 BURST. The hose has reusable fittings with bend restrictors both ends and the hose is reinforced. Available in a variety of colors including red, blue, yellow, and black. Hoses are made in the USA. It’s 1 to 3 days for shipping – most of the time they ship next day.
The coupler plugs are steel and they are most of the time because the SS balls in the couplers will pit a brass plug and will be hard to get apart. If you happen to want a brass 6 ball coupler it will cost about $1.00 more. Dee Evans at A1 Coupling thinks most people would use the industrial style couplers. If they want a universal coupler in brass that will work with either one it’s about $2.00 more.
The contact is Dee Evans and you can call him with questions and to place orders: 1-541-914-0606. Tell him MagicMtnDan sent you. The price per hose is $20.95 each.
Other hose options:
25’ Coilhose Pneumatics PU14-25B-B 1/4"ID x 25' Blue Flex Coil Hose With 2-1/4" MPT in neon green only $25.00 (from BigJ – he’s on www.SVTOffroad.com – The Ford Raptor SVT website)
25’ UltraBraid braided straight (not coiled) hose with removable air chuck and coupler assembly $28.95
http://www.virtualoffroadcenter.com/25-UltraBraid-Straight-Hose-Assembly_p_34.html
Reference info & pricing from the “Big Guys” –
Outback Air - 20’ Polyurethane coil hose (not UltraBraid) with removable air chuck is $50.00
Powertank - 25’ SuperFlex Braided High Pressure Coiled Hose HSE-8080 $44.95
25' SuperFlex Braided High Pressure Coiled Hose Our price: $44.95 http://powertank.com/products/productID/48
Accessories
Deluxe inflator with gauge – 100psi gauge includes rubber gauge guard and storage bag. I recommend using Outback's Deluxe Inflator which enables you to check pressure when inflating so you don't need to switch to a separate pressure gauge and you can let CO2 out if you put in too much pressure.
$55.00 - Outback Equipped | Outback Air CO2 Systems | "Is Your Rig Outback Equipped?"
There are cheaper solutions – usually kits with a variety of cheap stuff in them – available at Lowes and Home Depot and the auto supply stores. There are also more expensive solutions (see Powertank & others).
Tank Boot
Protects the bottom of your tank and has flat sides to keep tank from rolling when lying down.
$18.69 - Amazon.com: Power Tank TBT-6090 6.9" Diameter Tank Boot for 10 lb. and 15 lb. Tanks: Automotive
Mounting Brackets
There are many tank brackets available including some designed to mount the tanks to a roll bar (popular in Jeeps).
Powertank offers a variety of brackets POWERTANK - CO2 Air Systems
I found a Kidde brand #366424 10lb. Dry Chemical Fire Extinguisher Bracket online for $28.00 Kidde 366424 10lb. Dry Chemical Fire Extinguisher Bracket#
A 15# tank bracket can be found here: Amazon.com: Fire Extinguisher Vehicle Bracket - 15HB Heavy Duty - 7.25"-7.5" Dia. Shells: Home Improvement
Here is a real clever solution that will allow users to mount the tank at an angle still allowing the tank to be used (they should not be used lying down) involving a mounting bracket attached to a piece of bent steel: http://www.powertank.com/graphics/mount.2.jpg You can see a number of mounting ideas here: POWERTANK - CO2 Air Systems
The Savings
By going with the a la carte purchase plan here’s a package you could put together:
1. 10# tank $86.40
2. Regulator $55.00
3. Hose $20.95
Total cost of the above 3 items is $162.35 - add the $30.00 bracket and the cost is $192.35. Compare this to Outback’s $265.00 combo and you get to save $72.35
The Fine Print
Prices were correct and accurate at time of compilation of information (4/5/11). Prices, as you know, can change at any time. Prices do not include shipping or tax where applicable.
Disclaimer: I did this for myself and figured I’d share it with others who might be interested in being able to air up anytime, anywhere. I am not benefitting in any way from this except, like you, getting the lowest possible cost on a system that I can put together. I am not affiliated with any of these companies.
Let me/us know if you find other products for these systems that you’d like to recommend. This will ensure everyone has access to the latest greatest products. Now go air up!
The Tank
McMurdo Station Antarctica
How long is the hydrostatic test good for on these tanks? I remember when I played paintball some tanks had to be tested every year and others were every 3 years. How long is the life on these tanks?
M
MagicMtnDan
Magic Mountain
You could click on the link to the tanks or...you could Google it
KaiserM715
Kaiser Söze
Also why don't you have any way of keeping liquid CO2 from being discharged into the tire?
That is not an issue as long as you keep the tank upright. The liquid flashes to gas as the gas is used. If you turn the tank upside down or tilt it too much, you will get liquid.
A.I.I.Raciing
Dezert 8MYMNEY
Costa Mesa
That's a lot of very good information and I had planned on buying a Powertank, but since you've done all this work, I will use it to save me $.
One thing I didn't see was placement of the cylinder. CO2 should be at a 45 degree angle or more when being used. If it is laying down it will come out as liquid, You will still be able to fill tires and use air tools, but your tools will become cold and put a lot of moisture in your tires. You will also lose volume of gas that you expell from the cylinder compared to using it standing up and all gas coming out and no liquid.
I plan on making mounts like this for my truck, but at a 45 degree angle or possible 90 if space is needed.
http://i27.photobucket.com/albums/c174/copaseticdesigns/DMZ-16.jpg
http://i27.photobucket.com/albums/c174/copaseticdesigns/DMZ-3.jpg
http://i27.photobucket.com/albums/c174/copaseticdesigns/DMZ-24.jpg
http://i27.photobucket.com/albums/c174/copaseticdesigns/DMZ-17.jpg
chartguy
CO2 vs. Compressed air?
I'm a volunteer fireman, and we use compressed air SCBA tanks when dealing with hazardous atmospheres. I'm curious, do you get a lot more volume out of CO2 compared to compressed air? Our SCBA tanks are filled to 4,500 psi, for comparison. I live in a relatively rural area, so filling a CO2 tank means a drive to town. I can fill a tank at the fire station anytime. I'm not saying air is better, rather I'm asking how much (if any) I'd be giving up going with air vs. CO2. Air would be more convenient for me.
M
MagicMtnDan
Magic Mountain
You don't want to use these tanks lying down. 45 - 90 degrees is the optimum angle for use.
I did address the mounting of the tank and bracket options including a slick angled install where a bracket was attached to a bent piece of steel (45 degrees).
Mounting Brackets
