Wiz's Build
wiz1500
wiz1500
On to some current work..
The truck is getting a Winters shifter put in.. A few pic. of the custom brackets and center consol work.
Trans bracket.
I will have to extend the back of the trans bracket about 2 1/2" to get the cable centered.
More soon.
wiz1500
wiz1500
Ok front end is reinforced and the 4:88's are in..
The front really didn't need this as I run the correct skid plate that protects the lower cross member. It was just for piece of mind..
Make sure you clamp the plates and boxes straight so nothing moves around. also I don't recommend burning these plates in with the control arms still in place as these will compromise the rubber bushings.
wiz1500
wiz1500
Gears were a standard deal with only one exception you guy's may not know..
When setting the carrier back into the front case you have to squeeze said case so the shims will not damage there alum. pockets..
This is where we stand now with 4 days till Time Attack...
vanilla_gorilla
NorCal (Sacramento)
Why the new shifter? So you won't have T/H mode or manual mode? What about the 6 gears in the trans? Your shifter only shows 4 gears?
And pardon my ignorance on the above questions, just curious.
t_j
Chicago, IL
2010s don't have manual mode so no loss there. Mapping for 4 will be drive most likely every thing else mapping to its original position.
