Which Fumoto valve???
LVGH
I looked on Amazon for a Fumoto valve for my 2018 Raptor. There are all kinds of them listed!
Which one should I order? Please, no one say "the correct one".
Thanks!
Braaaaptor
Starbucks Enthusiast
The drive-thru
Plastic or metal oil pan? IIRC you can't use a fumoto on the plastic oil pans, but someone can chime in to confirm or deny.
I got the F107sx, but there are others that will fit. I like the F107sx because it allows you to rotate the plug and the lever is really handy. I'd also recommend getting a hose attachment while you're at it.
https://www.fumotooildrainvalve.com/f107sx.html
FoShizzle
Early 2018’s had the plastic oil pan and Ford switched to metal part way through 2018. You’ll have to verify which you have.
01Moch1
Portland Oregon
I have a late build '18 and also went with the F107SX. It works great! If ordering directly from Fumoto make sure to grab the hose and attachment to save on shipping.
Just be sure to verify which oil pan you have because it only works with the metal pan
