the other day i was driving around and the truck got stuck on 3rd gear and really high rpm's for about thirty seconds and then it finally kicked into 4th and onward. anyone else experience something like this? thanks.
sport mode and stock except a cai.
I like it. So, let me see if I got this right. So, you're in 4A in Sport mode, gear shifter in D. Then you shift to M mode. When you shift back to D, is it still in 4A and Sport Mode ? I like this . . if it's true.Yup, what he said. The first time you experience the “rpm hang” or “gear hang” it feels unnatural, but the 3.5tt is made to rev, you won’t hurt it in sport mode. If you pay attention to the shift patterns in sport, the truck is doing all it can programmatically to keep you in the power band or very close to it for street conditions. What I’ve found is that if I get into a situation in sport where I want higher gears for a while, I’ll pop the truck into manual and upshift; shift manually and then go back to sport, rather than mess with drive modes. I like 4a and especially in sport mode.
Yes. D and M do not affect the drive 'modes'. you can be in manual in all drive 'modes' that I am aware of.I like it. So, let me see if I got this right. So, you're in 4A in Sport mode, gear shifter in D. Then you shift to M mode. When you shift back to D, is it still in 4A and Sport Mode ? I like this . . if it's true.
Just curious why you like 4AMyth confirmed, @onthebrake !
selecting M while moving will “preserve” the gear selected, you up / downshift from there. This does not change your ‘drive’ mode or the transfer case. Most of the time I’m in Eco mode and hit M with the lever, drop 3-4 gears on the paddle, match rpms down to 3rd or 4th so I can get a drive off the exit ramps to overtake some plodding, latte sipping, text sending hypermiler too busy with reasons to actually pay attention to driving.
But I’ve also done the manual shift while in sport so I could cruise along in 7th or 8th for a bit and when done plodding, just click back into drive and let Lucille have at it shifting gears again.
Eco mode ? I'm pretty sure my '17 doesn't have such mode. OR DOES IT ????Myth confirmed, @onthebrake !
