Running wire from engine compartment to interior
gto19
hi
Does anyone know where I can get a wire from the engine compartment to the interior under the drivers side dash
Thanks
zombiekiller
OG BooBooRunner
New Orleans
hi
Thanks
I sliced a small slit in the rubber firewall grommet that the factory uses to pass the harness. If you attempt to just push the grommet to the side, it won't seal and you'll run the risk of water coming in through the firewall.
It is extremely tough rubber and pretty difficult to fish wires trough, unless you remove the fender liners to get easy access from underneath.
gto19
gto19
Small wire for a switch.already done using zombie killers method.super easy
pastorwug
Santa Maria, CA
I routed a 10g wire through the driver's side grommet for my Refrigerator. No problems, but wasn't easy to do.
RipReturns
Dallas
There's no need to splice and dice, there are already six wires bundled up on the firewall over the glovebox (passenger side, in the hood). There are two bundles of six truncated wires: one bundle goes the auxiliary (overhead) switches; and, the second bundle goes (pass through) to the passenger footwell (fusebox). I'd tell you which one is live - for me, it was on the left as you look from the front of the truck towards the passenger compartment - but Ford doesn't seem to know since it recently sent a warranty/recall/update that was wrong (I hate it when I think I'm wrong but I wasn't). These wires are rated at 5A, 5A, 10A, 10A, 15A and 15A (based on their gauge and the parallel bundle going to the overhead switches).
dewalt
6 thru wires on right hand side already
This was posted yesterday. You can get your count up by responding
