PSA....change out your factory lug nuts before it is too late 31k miles
goblues38
STL
I noticed I had one or two swollen lug nuts when i rotated my tires 7 months ago @ 27k miles. Because of a few threads on this site, i decided to buy the Gorilla Lugs from CJ Pony Parts.
I finally got around to rotating my tires again this weekend after an oil change. I had to work hard to get almost all of the lugs off. Thy had swollen up and the 21mm factory wrench, or impact drivers would no longer fit.
Ended up having to use SAE sized (forgot which one) impacts to get them off. Then had to struggle to get them to release from the impact socket.
Old lugs...center on was one that got stuck in impact socket
New look black
old look silver
Mister Pinky
OH
Honestly, that’s not a Raptor specific problem. I’ve seen it quite a bit in the rust belt, it’s just surprising it happened to you so soon. Where are you located?
Zeusmotorworks
One of the reasons I've used anti-seize on the lugs/plugs and most other parts on mine and customers cars for years and years. Started about 30 years ago when I was in aerospace manufacturing. Dissimilar metals generally like to react and bad things happen. Why at the very least we used a primer on just about every single fastener in the entire build. Some knob will try to tell you it's not a good idea because it changes the torque value, blah blah blah. Well of course it does, adjust accordingly.
Badgertits
Ma
swelling lugs has nothing to do w/ road salt & the rust belt has nothing to do w/ salting the roads...lol
Ruger
Northern Nevada
I have almost 88,000 miles on my 2011 GEN1, and since I bought it I have lived in both northern Alabama and northern Nevada. I rotate my tires every 5,000 to 6,000 miles, and there are no signs of the lug nuts swelling or seizing on the lugs. So I have to ask if Ford went to cheaper lug nuts on the GEN2 models.
4rdFan
Michigan
I had this same issue on my 2012 Ford Fusion. I found out about it the hard way when I got a tire blowout. I was stuck on the side of the freeway at night whacking the stock lug wrench with a hammer. Fun times :rolleyes:
CoronaRaptor
CANADA
This is the first I've heard of this, but then again I only used the factory lugs for the first year.
