Problem with front marker lights
surfer
Columbus Ohio
Recently my front marker lights went out. I have Dawsons hid lights with the yellow led ring, which I installed about 9 months ago. I checked all the connections and there is no power to the led markers, does anyone know which fuse these lights use.
S
surfer
Columbus Ohio
yes i tied into the marker lights on both sides and neither of the rings work. Just got off the phone with Dawson and he told me that it is a failure of the small little black actuator. He is already sending me two new ones. He knew exactly what it was the minute i told him what had happened. If anyone is considering HID lights I would look into Raptor Retrofit great product, great service.
S
surfer
Columbus Ohio
For anyone with a 2012 the led marker lights in the front of the truck are fused through fuse #30 under the dash passenger side wall. They are labeled as parking lights in your owners manual pg. 328.
Raptor Retrofit
HID Specialist
NY
Glad you found the fuse. Passengers side footwell for the marker lights.
Your rings were tapped into the side marker lights for power and when the driver failed the + / - fused together and popped the fuse. Good example why I recommend powering the rings through a aux switch.
Just unhook the quick disconnect on the led driver, replace the fuse and get marker lights functioning again, replace the drivers when they arrive and you should be good to go.
