? for you LED lighting experts.
Mac
NJ
I have 4 Ecco EW2304 lights they are 2 10W led bulbs rated for 1.2A 1250 lumen. I been looking at Rigid Dually lights they are 4 4W led bulbs rated at 1.1A 1568 lumen. Just wondering how 2 10W bulbs put out less light then 4 4 W bulbs. If somebody can explain this to me.
AlternativeOffroad
Los Angeles, CA
2 Reasons:
1. The LED Chip they are using isn't the same quality or bin as Rigid
2. A combination of the heatsink, the reflector, and the percentage they are able to run that LED at isn't the same as Rigid.
A lot of these factors bunched together is why that lumen output is lower than the Rigids. Hope this helps!
SilentShooter
Siesta Key, FL
LED's are rather technically advanced now. Its not the same as what most think. Most have complex driver boards to power the LED's. As they get better with them they are able to drive them harder. Also many LED units are now PWM (Pulse Width Modulation) so the LED is actually flashing at a very high frequency but your eyes are not able to distinguish the flashes. Some cameras will pick up on it, they do this to be able to keep the units bright but use less power which is less heat to dissipate
If you look at most High Power LEDs now the units have heatsinks attached directly to the LED to dissipate that heat. Most LED failures are due to heat.
georgesr
Oklahoma City area
It's about efficiency, smaller LED lights are more efficient so they can get closer to maximum output, as you get bigger on the wattage you start to drop off on the efficiency, like alternateoffroad said. So put more of the smaller LEDs together to better lighting makes sense.
hagak
FYI- Rigid lights quality is not what I would expect out of such an expensive light. My company needed lights for a non vehicle use and these lights fit the bill. The use was indoor of a factory that never exceeds 100f and is static mounted with no vibrations. The use though is 24/7. Well after a couple of months the rigid started failing. We took them to the lab and opened them up and discovered there was no thermal grease between the boards and the heatsinks and noticed that the lens had started to distort. We put some brand new ones in a thermal chamber at 100f and after a day the lights already went into thermal protection dimming the output. We did the same with a set of KC lights and they did not fail after 3 months and did not dim. Opened the KC up and they did contain thermal grease along with desiccant. We also noted the lens were much heavy in weight.
