Angle sensor and bcm code
Meat2022
Alabama
2014 raptor. Truck keeps throwing steering wheel angle sensor..but no lights coming on ever..like traction control or nothing just code showing. And I got a BCM code once. 5 star tune on my truck. Have the X4 tuner. I just replaced my suspension via fordged off road shock exchange. That's the only changes. Any ideas?
Meat2022
Meat2022
Alabama
I reset it ill reply if it pops back up again. Very odd. Makes me wonder if anything with my fox replacements were put in wrong if it would throw a code.
Meat2022
Meat2022
Alabama
P193C is the code. No dash lights ever. Just the code.
Meat2022
Meat2022
Alabama
So was you getting dash lights that made you replace the part? How bad is that repair?
pat247
Oklahoma
My Raptor has had the P193C since new, first time I saw this code was 04/01/14. I've cleared it several times over the years and it comes right back, never found the cause. I will look into the clockspring as I want to add a heated steering wheel to my Raptor anyway.
JefeAZ
Tucson
i had the steering angle sensor warning a few months back. replaced my clock spring and it solved my problem
This? How difficult an install?
Wrench light has come and gone 3 times in the past 2 weeks. Took it to a shop and they see P193C Steering Wheel Angle Signal and U0422 Invalid Data Received from BCM. Don't think U0422 is anything to worry about but are these codes related?
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
its easy. i still have some pics if you want them. send me a text. (831) 254-7562.
Meat2022
Meat2022
Alabama
Would it be bad if it only comes on when I use remote start? It never throws that code unless I remote start. Same with the other code for BCM.
