AC 120V Power point not working.
10SpdsOfFury
Jacksonville FL
Hey guys I have never used the 120V power point on my 22 until yesterday so my wife could run her laptop but none of the outlets work. Dash/Back seat/ bedside all have no juice, I also checked all the fuses and settings and not sure what to check next. I looked at my window sticker and it said 12V power point but nothing about the 120v 400w. Any help would be appreciated.
Donmatteo
Santa Clarita / Coronado
Is your pro-power enabled? scroll though the screens on your sync truck settings and there should be a graphic that said 400W and it should be green. If not, turn it on.
10SpdsOfFury
10SpdsOfFury
Jacksonville FL
I don’t have the pro power just the regular peasant inverter under the back seat. I looked high and low in the settings and found nothing to do with power. The outlet worked perfect in my 2019 Raptor
john_dexter1
@FordTechOne any advice on what to look at or just take it to the dealer?
Maybe even a call to the dealer before a visit and tell you over phone? Also, how old laptop? Did you try to plug in a bank and charge a phone from the outlet? Or charge something similar that you know takes less power? I'm thinking it's the laptop/charger
10SpdsOfFury
10SpdsOfFury
Jacksonville FL
It’s a newer laptop. I tried a bunch of different cell phone chargers etc and there is nothing. No green light or yellow etc.
Donmatteo
Also, somethings wont work based on voltage. Example is my wife's stuff. Here Dyson airwave (110) won't work but her Dyson flatiron (110) will. Her laptop (levano) and my Mac will too. Do you see an amber light on the plug in the truck? If there is no light, then there is no power.
Donmatteo
According to the advertising material, that receptacle is good for only 400 watts. AT 120 volts, that would be 3⅓ amperes. There are a lot of things you might want to plug into that, that would need more. I wonder if you've tried to plug in something that draws more than that, and triggered whatever overcurrent device (fuse or circuit breaker) is in place to protect it.
