2017 Raptor stock security systeem
dewalt
I installed this . Works good on arming with keyfob. Haven't got it to arm with 802a door handle thumb push. Is there a programming issue or what am I missing
I’m kind of reminded of
noise makers and remote disable are nice and all but, to paraphrase the commercial, what good is a monitor if you don’t do anything about it?
I’m thinking, something more like this
or this
Maybe fill the cabin with medical grade giggle gas, mellow potential joyriders and thieves out for easy police pickup?
D-Dub
Oklahoma
Alarm not arming with thumb push on handle.
Dewalt - the thumb sensor is not used to arm the alarm. The alarm is armed in three ways. 1. Depress the lock button on the inside door panel. 2. Simultaneously depressing the bottom two buttons on the door code entry panel. 3. Depress the lock button on your key fob.
Thanks - D-Dub
D-Dub
Oklahoma
Internal Alarm Sensors
I believe the internal sensors are on all Raptors, just not the remote access or shock sensor modules.
hmgt3
I've ordered the part but I couldn't find instructions on how to install. Does it go under the dash on the drivers side or passengers?
Any info from your will be a great help.
Thanks in advance.
Sent from my G8142 using Tapatalk
1DXmk2
Thanks in advance.
Mounts under the driver's side. There should be instructions in the box with the module, but it is pretty simple. Most difficult part is getting it zip tied in. I ended up using one zip tie and some double sided tape to hold it in position. If you've already received it and didn't have instructions in the box, they should be available on line. If I remember correctly, there are just two connectors. No programming required, completely plug and play.
Staff online
93,180
56,460
khunter
