$20.00 rear facing LED install video on a 2017 Raptor
Ruger
Northern Nevada
I got mine yesterday will install today hopefully if rain stops. The correct link is below but seems they are out of stock and another light comes up but without amber covers and much more expensive. I got mine for $11.99 shipped to me :)
https://www.amazon.com/gp/product/B01N2TP9FU/?tag=fordraptorforum-20
Yes, what comes up now are 72 watt spot lamps for $26.95. Spot lamps are the wrong solution for back-up lights. Flood lamps are what is needed for that application.
RaptorMaryland
Maryland
before you install can you do an amp check? Its real easy to do.
one of these lights drew 1.15 amps from my 12.5V power supply. That calculates out to 14.375 watts apiece - from the amazon reviews
Viper32
Sorry already installed them, will post pics later raining very hard here.
By the way how would I check what you are asking? I may want to do that on some of my other lights to see actual watts.
RaptorMaryland
Maryland
Use your cheep $5 Multimeter in series
link here on how. https://www.wikihow.com/Measure-Amperage
If you used easy to pull apart connectors, you still can do it real easy.
Ruger
Northern Nevada
Here is an alternate solution that has the advantage of plug&play instant gratification. Sylvania (brand name) has a LED replacement for our famously anemic #921 back up bulbs that is easily twice as bright as the standard incandescent bulb. It is marketed as a Super Bright LED in the ZEVO line and has a lifetime warranty. It has six LEDs mounted radially, draws 2.5 watts at 12.8 volts. It is no longer (deeper) than a standard #921 bulb and is only a little bit bigger around, so clearance inside the rear light housing is not an issue.
Wal-Mart does not have them in the stores, but offers them in the web site for $22.99 plus $5.12 shipping. O'Reilly Auto Parts has them in the store (instant gratification) for $24.99 (cheaper).
It's a good solution, inexpensive, installation is a snap (use of dielectric grease is recommended), and they're warrantied forever.
Viper32
I got 1.41 watts on one and 1.42 on the other one with 12.6 volts input.
Ruger
Northern Nevada
Be advised that too much light can swamp the rear camera. You can have too much of a good thing. As with most everything there's a sweet spot.
