BRAPPPP
Yeah I'll admit the stock HIDS are nice. They could definitely be brighter but these lights like u said have a little softer cutoff and cover a good part of the road.
Does retro make an hid kit for the new eom headlights as well. I want the brightest output by my headlights. Not worrie about gettin flashed
1, the OEM housings look nicer to a lot of people than retrofitting a halogen housing
2, they're DOT, so you won't get hassled at inspections if your state has them (and yes some guys have been hassled for retros in halogens)
3. they make the truck look like a newer model year with newer style lights instead of retro'ed old style
4. they don't have an annoying sharp cutoff line. I know some get obsessed with a sharp cutoff, but that sharp line of BRIGHT LIGHT to PITCH FRIGGIN BLACK in front of me drives me nuts because any little bump I hit that thing is bouncing up and down several feet when it's projected several hundred feet down the road, where an OEM HID with a soft cut off you don't get that pitch black to bright white line bouncing all around, you don't even notice the light distance changing on little bumps and dips in the road
5. they have MUCH better shielding on the OEM HID and ballast setup so there's zero RF intereference on the radio. Even quality aftermarket HID setups with proper grounding still have interference on weaker radio stations.
All that said, I still went with aftermarket HID projectors/bulbs/ballasts in my 2013+ housings, despite the annoying sharp cutoff and losing my favorite radio station because it's a distant broadcast with a weak signal, but mostly because I scored my housings for $200 each with no ballasts, so I used the money I saved to upgrade inthe OEM 13+ housings. The light output is kick ***, but even OEM HIDs blow the factory halogens out of the water and do have their benefits over aftermarket.
