What is this line?
Madcowranch
Genetically Modified
OK
Have a leak in this line. Looks like it goes to the a/c condenser. Rubber factory crimped to steel lines.
Madcowranch
Madcowranch
OK
Yukon Joe
Trafford, PA
On the rad side you will need to remove it with a 5/8" or 3/4" line wrench (flare nut wrench). If it's the bottom hose on the rad, you'll want a plug or catch bucket under it. You'll probably lose about a 1/2 qt of oil as it drains out of the cooler.
Not sure how to remove on the engine side. But that can and everything will have to come off. No way to separate the rubber from the metal. The whole line needs to be replaced.
Are you sure the hose is leaking and its not something dripping onto it?
@Yukon Joe :baby: :baby:
www.runraptorrun.com
Madcowranch
Madcowranch
OK
Run Raptor Run | Great Lakes Raptor Excursions (GLRE)
Pretty sure. The only thing above it is the big radiator hose. I cleaned it off good and I'll drive it around a little to see if it reappears.
Madcowranch
Madcowranch
OK
That line comes from the compressor to the condenser. discharge line. you need to evacuate the ac system first before you remove.
We'll Sumbitch.:rage:
---------- Post added at 03:26 PM ---------- Previous post was at 03:16 PM ----------
Looks like a trip to dealer. I hate going to the dealer. Unless there's a way I can evacuate the system. I evacuated my lower colon just a little bit ago successfully. So I may try it
beemerman
Worlds most famous beach
well you didn't hear this from me. you could bleed off the Freon with the shrader valve. just use a small screwdriver and bleed off the shrader.
then once you get the new one on. most any shop can evacuate and recharge
