40" behind the grill mounts.
ossachuk
North Western Ontario Canada
Hey guys. Just got my light bar. I was preparing to install the mounts when I realized they don't fit. The bumpers for the grill seem to be in the way. Is there anything I can do or do I need to order different mounts?
Backinblack
Vancouver, B.C
I had the same issue exactly. Put the bracket in a vice and grind the edge of it off. Probably take off 3/8 " or so. Hit the raw metal with some black paint and your good to go. If all else fails, buy the brackets from Rigid. I would also replace that ****** torx screw with a stainless bolt, you can get nut and washers below no problem.
ossachuk
ossachuk
Thanks guys. I will be ordering the brackets from rigid. Can't wait to get this baby installed.
Yukon Joe
Trafford, PA
Second the replacement of the bolting hardware.
@Yukon Joe :baby: :baby:
www.runraptorrun.com
