Cheap cheap light bar
Tiberius
Isn't rigid bracket just like an L with some holes in it?
Sent from my XT1056 using Tapatalk
t_j
Chicago, IL
ZBoater
This is what I used to mount my totron 40" but the bar is a little too deep and the cooling fins catch on the lower trans cooler line. I will be trimming the fins on the back where the line is as even with a custom bracket I don't think I could bring it far enough forward to clear the line.
That's not the same as the cheap Amazon bar, is it? I'm hoping that one will fit right below the F O R D.
blackraptor99
Katy, TX
This Rigid Bracket with the Tuff Stuff 40" bar works perfect. You can adjust the height of the bar and put it perfectly below the F O R D lettering behind the grill. 10 minute install not including splicing into under the hood Aux wiring.
Tiberius
That's what it appears to be... but I figure ten bucks is worth saving half an hour fabricating and painting something of my own creation.
For sure. I just wanted to make sure it wasn't something different than I was thinking.
