1.5 spacers with 37s?
JoseCollazo
Hi guys, Do you think is posible to have 1.5 spacers with MK2s 37s OEM wheels with out having any issue?
Aaron
Meme Corps Commandant
WA
With 37's and stock fenders. OEM wheels are a better setup to avoid rubbing than using a spacer or a 0 offset wheel. I ran 37x12.50r17 BFG Projects and had zero rubbing on Mid and Top perch, but then went to a set of 0 offset wheels and had to do some pretty major trimming to the bottom rear of the flare on my drivers side to avoid rubbing.
I'd say no spacers, at least from that standpoint. You'll also get a lot of guys here who will say to never run spacers, but if you buy quality ones, it shouldn't be an issue from a reliability aspect.
mstennes
I went with Method wheels in a 18” as they are the exact offset of the factory Raptor wheels.
Aaron
WA
Would those be +34mm then? I'd only seen +18
Clockton
Northern CA.
I think the Holeshots are the only wheel that has a factory offset. I just put some wheels on that are .5” difference with 37Ko2s and this is what you need to trim.
Aaron
WA
People should bear in mind that 37" KO2s are slightly smaller than a "true" 37. I believe the 37x12.50r17 is right at 36.3
