Perch Mod Still Possible on 2017?
dtt255
Southern Cali.
Two piece collar that allows you to level out the Gen2 without having to take the shocks off the truck.
Still needs Anodizing and Laser Etching.
Any idea of cost yet? How would
Something like this go on without removing the shock?
SilentShooter
Siesta Key, FL
That is easy. Its a two piece design. You would use a spring compressor on the springs then since no load you push up the spring seat take the two piece collar and bolt it together around the shock in the spot the stock seat was. Once locked in place you then remove the spring compressors
