bigrig
Looking for advice here. I am trying to install the fox 3.0 coilover with the rogue UCA and LCA slot delete kit.
Because the Rogue UCA has heim joints at the top and is intended to be adjusted there to align the wheels, Rogue says to flip the bolts inward so they can be removed without removing the coilover.
So far everything assembled fine but the bolt for the UCA won't fit anymore because of the external reservoir exit is in the way. I am thinking about cutting the bolt and using a smaller nut, but not sure if that is a good way to go.
Any suggestions would be appreciated.
