Swapping Shocks need some info
s.reef
My shocks are worn and due for a rebuild, I bought a set of new take offs and plan on putting those on. Question about bolts and nuts? First are these one time use? I was planning on just getting new ones anyways but was curious. Also does anyone have the part number for the bolts/nuts front and rear? Thanks in advance
Deleted member 12951
I've had my shocks off a couple times (took off to do mid-perch) and had my ICON's off several times without any issues. The only ones that I know are supposed to be one time use are the u-bolts since they are torqued to Yield and bed bolts but I could be wrong.
STRUT MOUNT BOLT - W712104S900
STRUT NUT- W715151S900
SHOCK MOUNT BOLT - W506545S439
SHOCK NUT - W520214S441
REAR BRACKET BOLT - W714299S439
REAR BRACKET NUT - W520215S441
Went to Tascaparts.com so might want to double check
oxfordraptor
I used these on the rears when I went to 3.0's upgrade to grade 8 for $17 its worth it.
McMaster-Carr
High-Strength Zinc Yellow-Chromate Plated Cap Screw
Class 10.9 Steel, M12 Thread, Pitch: 1.75, 70mm Long
95327A695
Zinc-Plated Class 10 Steel Nylon-Insert Locknut
M12x1.75 Thread Size, 19mm Wide, 12mm High
94645A230
Not sure on the fronts but it looks like they covered it above possibly.
