Evil Twins
I'm in the midst of setting my front ride height and need to know how much I can raise the front without causing major issues. I have a torsen front diff, Fox 3.0's on all 4 corners and WSI SD springs in the back. The front is currently set at about 26 1/4" from hub to fender flare (shown in pic) and obviously needs to come up a bit to be level with the back.
The measurements I got from searching old threads is 26.5" for mid perch equivalent. Is 26.5" the max I can go, even with 3.0's?
Thanks in advance.
Thanks in advance.
