VisionX XPR Light Bars are HERE!
Crikk
FRF Lady
FRF Lady
Crystal lake il
What is the range and output of the 20"? I had a rigid E2 hyper spot 20" in the lower grille on my last truck, I was amazed at the throw of that light. I need a 20" on my new raptor, how do you think it would compare?
AlternativeOffroad
AlternativeOffroad
Los Angeles, CA
Lumens will be almost identical to the E2, and distance should be a little more due to the larger reflector size. 20" with brackets also runs at $599 so considerably cheaper. Also the 20" has tilted end reflectors for a flood effect
AlternativeOffroad
AlternativeOffroad
Los Angeles, CA
James, do you have an overall end to end length for the 51"? I want to make sure it'll fit with my roof mounts that I still haven't mounted yet!
It's 50.6" end to end, but we have billet endcap mounts that center the mounting point on the end, that pushes it out about an inch extra total. So you should end up right around 51.5" end to end if you use our billet mounts!
93,171
56,440
jumpcutter
