Rigid 54" RDS with ADD mounts
justvettn
GTA
Nice! Can the mount be installed higher or lower or does it only fit in that one spot?
2008fx4
2008fx4
Tucson, AZ
The brackets are designed to be put in only one place - using an existing rivet/hole underneath the weather stripping. I'm 6'11" and barely notice the bar at all. It definitely isn't in the sight line unless you look straight up. However, it does create quite a bit more wind noise.
93,171
56,440
jumpcutter
