ZBoater
- Joined
- Mar 9, 2014
- Posts
- 1,980
- Reaction score
- 865
mine doesn't fit. using those brackets. What do I need to do to make it fit?
You mean the bar doesn't fit? It's a 40" bar?
Leave the brackets a bit loose while you're fitting the bar. They have about 1" play on each end. If your not fitting by more than that, you have the wrong size light bar my friend.
---------- Post added at 08:19 PM ---------- Previous post was at 08:14 PM ----------
I should also mention that it's a tight fit with the fins in the back. I had to kinda jam it in there. While keeping the bottom of the brackets loose I tightened the bolts going into the sides of the light bar. Once those were tight, i tightened down the bottom ones that go into the car. Careful not to over tighten those, they could strip. And the fins on the back of the light will definitely be touching the radiator.
