First Oil Change on my '14
R1jamn
My '14 scab reached 2000 miles on the clock and it was time to change the oil and filter.
I prefer doing my own maintenance.
I went with Mobil 1 full synthetic and a Motorcraft oil filter.
I did not remove the skid plate. I removed the access door though.
I had read on this forum that using tin foil works good to keep the oil off the skid plate and thus keep clean up to a minimun. So I tried it and it worked great.
The Motorcraft filter has a geometry at the end of it that is unlike most filters.
I would recommend that you pruchase a socket style filter wrench (3/8 drive) that fits the geometry of the Motorcraft filter.
I also use a product called "Clean Funnel". These work great too.
I filled it up with 6.5 quarts and started it up, then I shut it off and let it drain back down, then filled it to the correct level on the dip stick.
The owners manual was spot on at 7 qts exactly.
skyscraper
I got the same drip pan from Walmart and I think I'm going to Ditch it... Oil drains way too slooooooowwwww
R1jamn
R1jamn
Was the factory oil filter torqued on there pretty good?
Let me tell ya. That SOB was on there good. It was not fun.
I gave that factory filter a verbal whipping like you wouldn't believe.
---------- Post added at 08:20 PM ---------- Previous post was at 08:18 PM ----------
It works great skyscraper.
Did you pop open the relief cap? It will pour right out when it is open.
skyscraper
Oh no I meant it drains into that pan slow. I made the mistake of using it under my 6.7l cummins and almost had oil spill everywhere! I had to put the plug back every min so that it could drain through the gray screw on top.
Btw: bedrug and bakflip looks great! That's the same setup I want to go with
R1jamn
R1jamn
You're right. LOL
It was scary slow. I kept an eye on it. It started to fill up quick on the top.
I thought I was going to have an oil slick mishap.
But it drained into the pan before it overflowed. Thankfully.
I had seen another one just like it but with out the top. I may get that one.
You'll be very happy if you go with the Bakflip and Bedrug.
R1jamn
R1jamn
This is what I used to get the factory oil filter off.
I purchased it at Napa auto parts.
Humvee21
Just FYI, I have that same oil pan and the cap on it is crap. It will break and leak. Just watch out for that
R1jamn
R1jamn
It's not top quality that's for sure. I wouldn't place this drain pan into my vehicle at all.
I take the drain pan and dump the used oil into a 2 gal gasoline container, which is much better quality.
Then I take the gasoline container to the local auto parts store for disposal/recycling.
I went down and bought this drain pan today. I need to donate the black oil pan to somebody now. LOL
The new one has an open top. I will not worry about it overflowing now.
