GEN 1 Twin Turbo 6.2 Raptor build: DIY Tri-Y turbo headers
A
Aksubiedubie
Alaska & Washington state
Hand formed intercooler end tanks out of 0.0625" ... 5083 aluminum? I forget.
It held plenty of pressure in the STI with the 750hp garrett core that I built. Ran 33psi of boost on that out of an EFR 8374 (79lb/min or ~790hp)
4 inch outlet. Trimmed it a bit after. I wanted minimum volume while keeping efficient flow (based on eyeballing a ton of optimized intercooler end tanks from formula 1, and other CFD simulation images on the internet)
Spent some time with a die grinder after welding to smooth the outlet towards a mini velocity stack type config.
Finished product with 2 3" inlets and 1 4" outlet:
After the intercooler I pre-fabbed the Y pipe for underneith using solar flux. Worked pretty good. Feels nice not using a ton of argon... shit is expensive nowadays.
Here is the final config and some of the last pictures I took since a week or two ago.
Got some matte black/reflective blue graphics from josh @ rappygraphics
---------- Post added at 09:42 PM ---------- Previous post was at 09:40 PM ----------
You sir are an inspiration. Keep up the good work. I hope it goes smoothly!
Sent from my VS987 using Tapatalk
Ha thanks. It's been kind of a *********** but I'm really happy I got the hardest part done. The downpipes and Y pipe will be easy since I got a pipe expander and can just do short slip fits with solar flux.
Darthyota
Alberta Canada
did you buy a motor to have for external mockup? or have you been pulling your motor out every time you want to mock up/fab
Uzzirider
PHX
You know, I heard you can get a raptor with factory turbos now. Might be easier? :biggrin:
Sweet project - impressive fab. Will you keep stock internals?
A
Aksubiedubie
I like my V8 lol. Factory for now i don't see a need for over 600whp .
Probably call it done for now and keep around 550 whp at around 7 psi to keep it reliable.
Sent from my SAMSUNG-SM-G870A using Tapatalk
---------- Post added at 03:17 PM ---------- Previous post was at 03:14 PM ----------
Used like 5 1/16 filler rods and 4 1/8 filler rods to build these up enough to drill and tap with 3/8 npt for a 316 SS barbed fitting for oil drain.
---------- Post added at 03:19 PM ---------- Previous post was at 03:17 PM ----------
Here's to a N/A intercooled motor [emoji48]
Scaling the maf was very easy with some inputted math functions in hptuners.
93,171
56,440
jumpcutter
