Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford SVT Raptor General Discussions [GEN 1]
Power steering pump
This is a discussion on Power steering pump within the Ford SVT Raptor General Discussions [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
I'm started getting inconsistent steering feel in my truck recently. Sometimes it's stiff to turn the wheel and sometimes it ...
Old 03-14-2017, 12:59 AM   #1 (permalink)
Mjparsons's Avatar
Default Power steering pump
I'm started getting inconsistent steering feel in my truck recently. Sometimes it's stiff to turn the wheel and sometimes it gets very easy to turn. Could this be a pump issue?
Mjparsons is offline   Reply With Quote
Old 03-14-2017, 03:00 AM   #2 (permalink)
CineSLR's Avatar
Roaming Shutterbug
Yes, first step is check your fluid levels...
Sent from my VS987 using Tapatalk
CineSLR is offline   Reply With Quote
Old 03-14-2017, 11:17 PM   #3 (permalink)
Mjparsons's Avatar
Fluid levels are solid. Now that I'm paying more attention it feels wobbly now if the steering wheel is centered, like theirs a little play left and right. But definitely feels firmer at times and easier to turn at other times.
Old 03-15-2017, 12:38 AM   #4 (permalink)
RDFTS's Avatar
aka Rick
Check the rack too. Lift the front and grab the tire from 9 to 3 and see if the tie rod seems loose where is goes in the rack. Best to have someone hold the steering wheel. Had a similar issue and I had to move the boot on the tie rod out so I could see how it was reacting in the rack. Got the rack replaced under warranty.
2014 RR SE SCREW | #792 of #3396 in RR | #4568 of #22409 Total | My Mods: Click Here
2008 Shelby Mustang GT500 Torch Red Convertible | #58 of #463 in Torch Red | #249 of #2070 Total
Raptor Runs: TRR & Raptoberfest 14'/15'/16'/17'/18' | Time Attack 14' | Snoball 15'/18' | AR Run 15' | TRR Baja 16'/18' | Private Baja Jan 17'
RDFTS is offline   Reply With Quote
Old 03-15-2017, 01:24 AM   #5 (permalink)
Mjparsons's Avatar
I'll have the rack checked out for sure. It's hard to tell what's causing it. Could be shocks needing rebuild, pump, or rack. Or all 3.
Old 04-14-2017, 01:06 AM   #6 (permalink)
Mjparsons's Avatar
Ok so I just had my pump replaced after having my steering get very stiff last week. It was leaking so they replaced it but my steering still feels stiff. Can't tell if it's supposed to be this way or if something is still in need of repair.
Old 04-17-2017, 03:21 PM   #7 (permalink)
AndysLog's Avatar
not many components past that. steering rack then the end links.
AndysLog is offline   Reply With Quote
Old 04-18-2017, 02:54 PM   #8 (permalink)
thearizonacowboy's Avatar
Anyone know why I would be getting random vibrations in the wheel? Turning in parking lots will do it. I've beat the hell out of it, jumped it maybe 100 times in a couple months and it hasn't gotten worse or better. Fluid looks fine and at the proper level.
thearizonacowboy is offline   Reply With Quote
Another Power Steering Pump... pillowsoft Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 8 01-31-2017 02:43 PM
Power steering pump went bad Trapcity Ford Raptor Problems and Questions Forum 11 02-08-2016 03:10 PM
Power Steering Pump SVT_4X4 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 1 09-16-2014 06:56 PM
Power Steering Pump VLASA Ford Raptor Problems and Questions Forum 10 02-28-2014 04:15 PM
Power steering pump whining? DirtNasty Ford Raptor Maintenance Forum 8 01-17-2013 01:57 PM
