Here's the text in question from the article:
"It's also remarkable that they chose to use the extended cab version of the F-150 for the Raptor launch, as you really notice the chassis flex on rough pavement at low speeds, an effect no doubt amplified by the huge daylight opening created by the anchor-less front and rear doors.
This chassis shimmy gets amplified at low speeds on uneven pavement in a way that makes the whole machine seem active, which is more annoying than unsettling. Over 30 mph, or as soon as the suspension gets involved this all settles down. Will the wheelbase trade-off be worth a B-pillar when the four-door appears? How about a regular-cab Raptor?"
His criticism stems from Ford's use of the SuperCab that goes without a B-pillar which isn't practical with the smaller front-opening rear doors. We're very fortunate Ford gave us this design as I would probably not have purchased the Raptor if it was only made in a regular cab which the author is asking about.
Methinks the writer is a car guy - probably a Camry driver - who is bothered by the squeaks that come from the four doors' seals. The SuperCrew Raptor won't have this since it will have a B-pillar.
I'll gladly pass on the longer wheelbase and reduced manuverability that comes with the B-pillared Raptor SCrew.
