HORN HIGH ACES
What tires are you running and at what air pressure?
Nitto Trail Grappler M/T
35/12.50R17
40psi
Also noticed above the front shocks, there is a blue piece of metal that says: "ReadyLift Suspension Inc"
It appears to be this:
https://www.readylift.com/t6-billet-ford-raptor-svt-2-0-leveling-kit-blue-1.html
They put a leveling kit on, instead of moving the perch!!
35/12.50R17
40psi
Ok so a few things here:
1) Get rid of that readylift spacer if you plan to get your truck into the dirt. Full droop with that spacer in will be more than your control arms are designed for which can damage things.
2) With that spacer in, if you're on bottom perch the ride should be pretty plush and 'roly poly' like. It should soak up most things without feeling unsafe like you said.
3) because of #2, I'd say you need to get your shocks rebuilt and at the same time you can do #1 and also have them set to mid-perch.
4) You could also add the Geiser progressive springs that UTV inc sells. Lots of guys run those and love them.
My truck feels really stable and planted on the road and I'm running stock shocks/springs all the way around. A rebuild is your lowest cost option to try to remedy the situation.
I am going to have them rebuilt through the shock exchange, and set mid perch. Once I get them in the mail, and pull the old ones, I'll get rid of that spacer. I'm going with stock rebuilds at mid perch, with schrader valves.
Glad to hear your truck feels planted. I'll report back if this fixes my problem.
Thanks all.
