Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Sync Ford Svt Raptor
This is a discussion on Sync Ford Svt Raptor within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
good afternoon! I apologize for my English (gives Google) help to solve a problem on the Sync updating on Ford ...
Old 04-01-2017, 04:01 AM   #1 (permalink)
lozivka's Avatar
Junior Member
Unhappy Sync Ford Svt Raptor
help to solve a problem on the Sync updating on Ford Raptor svt of 2011.
essence such is, I downloaded from the official site of Ford updating under the car (using VIN) unpacked it installed on Usb (formatted in Fat 32) in Usb a nest on the started car, and updating doesn't begin. I tried many times and all but everything is ineffectual = (I can what not so I do that?? help who knows! I will also wait for the answer from thanks
lozivka is offline   Reply With Quote
Old 04-01-2017, 12:33 PM   #2 (permalink)
MTF's Avatar
MTF
@lozivka, Assuming you have the Nav Voice.
If not your files are a little different but the process should be the same.
Maybe this will help;
First make sure you run a "Vehicle Health Report" (if you can)
And if your Ford Owners webpage is asking to run a Version Checker, you may need to do that first as well.
You do need to install all the files and the folder after unzipping made that new folder, then select all and copy to the empty USB.
Not the Folder in the left column, only everything in the right window pane.
In "Windows Explorer" go to Tools/Folder Options then to "View" and select Show Hidden Folders, Files and Drives.
Hope this helps.
More info here: Sync update V4.4
Whipple 700+ HP 800+ in the works, Oil and Fuel pump upgrades, Custom Deavers +2 Rear Springs, Axle Exchange Driveshaft, Rogue Racing Traction Bars, Hellwig rear sway bar, Pace Edward electric bed cover with remote, Pop & Lock Tail Gate lock, Mud Flaps, Window Rain Guards, EZ Down Tailgate, Bed Rug,
Future Installs: Brembo Brakes 15" Gran Turismo
MTF is offline   Reply With Quote
Old 04-01-2017, 07:21 PM   #3 (permalink)
You will need to go to the dealer and have them update via obd. Also see my bluetooth connection topic in gen 1 section for solving sync bluetooth prob
Black_Valkyrie is offline   Reply With Quote
Old 04-01-2017, 07:29 PM   #4 (permalink)
MTF's Avatar
MTF
If you do a Master reset and do all the instruction correctly.
You will not need to go to the dealer. Unless you have other issues.
Tags
sync
Ford Sync - NAV to No Nav 2011 Ford Raptor 2011 Ford SVT Raptor Forum (Reply Only) 11 12-05-2012 01:28 AM
TSB 10-25-12: 2010 Ford Raptor SYNC Call Sound Quality Background Noise Voice Recognition Issues BigJ Ford Raptor Problems and Questions Forum 0 05-26-2011 12:41 PM
TSB 10-13-4: 2010 Ford Raptor SYNC Non-Navigation - No Turn By Turn and/or Unable to Find Location BigJ Ford Raptor Problems and Questions Forum 0 05-26-2011 12:12 PM
TSB 10-2-8: 2010 Ford Raptor SYNC System Defaults or Stays in Privacy Mode BigJ Ford Raptor Problems and Questions Forum 0 05-26-2011 12:06 PM
Prolong the life of your Ford Raptor SYNC USB Port Xjrguy Ford Raptor Audio/Video/Electronics Forum [GEN 1] 5 09-22-2010 06:54 PM
