memberthttime92
I installed the 2014 raptor retrofit headlights and relay on my 2012 raptor and the high beams are stuck on when the headlights are turned on. After my first attempt to install them I noticed the high beam issue and was sent a replacement relay. When I just installed the new relay from Morimoto I'm having the same issue, high beams stuck on then when I manually turn my headlights off by the knob to the left of the steering wheel the lights cut to the low beams for a second and then turn off completely. Is it possible I got two bad relays in a row? I checked all my grounds and they are all good. Has anyone experienced this? Just wanted to see if I maybe did something wrong that is causing the issue. Thanks for any advice anyone can give me, it's getting hard to not be able to drive at night due to my high beams blinding oncoming traffic. I am trying my best to avoid installing my old headlights back in, and having to then reinstall the retrofit headlights when the issue is fixed.
